bruceb58
- Joined
- Mar 5, 2006
- 30,797
For the money, you can't beat it. I have the enhanced Toyota software as well. I need that for my Lexus to properly bleed my brakes since the software controls the ABS unit. If you are a pro and running a shop, you may want something different.
For the MAF, the voltage is pretty constant for a given RPM so there isn't a whole lot of value in plotting it unless you take the car for a drive and set up the plot to have RPM vs MAF voltage. This software will store the plots so you can look at them later. So far, I have only used the plots to diagnose O2 sensors.
I actually think its not a bad idea just to replace the MAF every 120K or so. Probably also not a bad idea to clean them occasionally with MAF cleaner. The OEM MAF for my Silverado was $82 from Amazon with 2 day shipping. OEM MAF for my Lexus was $75 from Rockauto.
On my Lexus, I just recently took the whole top and front of my engine apart to do timing belt, valve cover seals, etc...I cleaned the Throttle Body very well with throttle body cleaner. I had a slight hesitation before I cleaned it and I got rid of it. My throttle body has small air holes just after the throttle plate that may have been clogged.
