FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
It should only lock down when in reverse. It is supposed to be able to move in forward so if you hit an underwater object with the lower unit, the motor will kick up instead of breaking things.
as well as what jason said,if the problem started after a service,the service tech could have left a small washer out.it goes on the shift shaft and moves the lever for the reverse lock hooks.
Originally posted by JasonJ:<br /> It should only lock down when in reverse. It is supposed to be able to move in forward so if you hit an underwater object with the lower unit, the motor will kick up instead of breaking things.
Thanks for your response. The reason I noticed what I thought was a difference in the way it was responding was because starting last April the OB is mounted on a system on a Sorensen 9' dinghy where you don't have to take the OB off the dinghy to raise it up for storage on a swim platform. It seemed that recently when I raised the dinghy/OB up onto the swim platform that the OB had more play in it then before. It sounds like rather than an issue with the OB lock down that it might be an issue with the dinghy/OB interface. I appreciate your response. Thanks.
Originally posted by B20:<br /> as well as what jason said,if the problem started after a service,the service tech could have left a small washer out.it goes on the shift shaft and moves the lever for the reverse lock hooks.
