obsolete ecm
it looks like my ECM is obsolete. i have a 1999 mie 350 mag mpi ski. any suggestions?
More info then just its obsolete?
What is the serial number and is your s bad and how do you know?
99tige2100
my serial number is 0L 305998. we just put a reman block in it. has a new ignition mudule, new cam shaft sensor. new fuel injectors. new spark plugs. new wires and Distributor. its kind of like this is what we are down to.
The original was a MEFI-3 and the new is a MEFI-4 conversion
If you ECM is bad (your sure its bad and has been tested) then might get it repaired at OBD Diagnostics or buy a reprogrammed one from them at $1795
https://obd2allinone.com/mefiecms.asp
