OCM Cobra 3.0 Stalls in neutral
Hopefully someone can help me with my problem. The problem occurs when the engine is warm and running, no problem in the start up, I can run all day with no problem but when I return to neutral it will stall. I already Replace the spark plugs, fuel filter & clean the carb. but yesterday after 2 hours cruising I was arriving to the dock and it happen again is like the engine get overflow, I try to rev up but nothing. Any suggestions?:confused:
Thank you
chiefalen
Re: OCM Cobra 3.0 Stalls in neutral
How does it idle and at what rpm. In the water in gear.
llbt
if it happens when shifting it could be your shift interupt switch shift cable bad or out of adjustment
