AnglersEdgeNY
Thread starter- Joined
- Oct 13, 2007
- 34
The motor is a 86 Johnson 225. The compression test I did yesterday gave me an odd result. I used the old gaskets which where removed and put back a couple of times for the test (not the best idea).
First test showed
Cylinders 1,3,5 at 78,85,90 and Cylinders 2,4,6 at 56,55,63.
The second test after tightening the bolts a little more (I didn?t have a torque wrench with me, we were there to do other work but my friend brought a compression gauge so we were curious)
Second test showed
Cylinders 1,3,5 at 90,94,110 and cylinders 2,4,6 at 45,105,75
Why would cylinder #2 go down after tightening the bolts when all the others went up?
Also since the lower unit of off the motor can a hose be connected directly to the water tube to run the engine.
First test showed
Second test showed
