Odd hole near engine mount
tehlib01
My boat had a replacement 5.0 mounted in it several years ago after the 4.3 was removed. Under the engine mount I noticed a small hole, sometimes it leaks out this brownish stuff, not a ton, but its there. I can wipe it off.
Could this have been drilled when the 5.0 was put in for something to do with the engine mount?
This image has been resized. Click this bar to view the full image.
I also noticed a smaller hole in the fiber glass in the same area, opposite side right at the bottom where the wall goes up to the engine mount that have leaked a similar stuff. It's very tiny.
Unfortunately I wiped off the stuff prior to taking the photo
GA_Boater
It looks like the motor mount behind the oil filter is sinking into the stringer.
