odd magneto query??? reverse polarity?
nwcove
what exactly is reverse polarity in respect to different magnetos? :confused:
ronward
Re: odd magneto query??? reverse polarity?
What??? By the way, how does a motor with no pee hole cool itself?
Joe Reeves
Two different magnetos?... I haven't a clue.
However, all magneto magnets have two poles, a north pole and a south pole. The "north" pole swinging past the coils would be a positive polarity, the second "south" pole would be as negative polarity. At least that's how I've always looked at it.
Why do you ask?
ronward
not sure about the original question. don't know what it acyually is asking. just thought I might try another avenue to find out how a motor with no pee hole cools itself
Joe Reeves
Thousands upon thousands of outboard engines were manufactured before the water telltale feature came into existence. The telltale was just an added feature (late 1970's) to visually allow the boater to have an idea of the water pressure being exerted via the water pump. It has nothing to do with the actual cooling of the engine.
ronward
but where does the heated water go? or how does it cool the motor?
nwcove
To different magnetos?... I haven't a clue.
Why do you ask?
im doing a " just for fun" conversion to electronic modules on a 58 10hp,its all wired up ( just two wires! lol) per coil. but getting no spark. the trouble shooting guide says " an erratic spark or no spark at all may be due to reverse polarity of coil or flywheel magnets".
maybe a diode in those little modules??? electricity isnt my strong point!
nwcove
its an open system.....cold water in.....hot water out . just no tell tale to confirm it.
HighTrim
Tim reverse the wires and it will work. That is a common problem on them.
ronward
hot water has to go somewhere. pump would lock cause water aint movin...................ten pounds of **** in a five pound bag???????? just don't add up
ronward
didn't mean to hijack ya. thought about ur prob and think maybe u switched some wires(polarity)
HighTrim
Ron your question is too general. Perhaps start your own thread if you have questions about cooling systems. A model reference would help us describe it in detail. There are many different varieties.
