Scaaty
- Joined
- May 31, 2004
- 5,180
Re: odd shaped fuel cell
Perfidiajoe has it nailed.<br />You don't understand how guages work. The ONLY way for your method to work would be a square, level tank. Your guage measures (by float) the LEVEL. It does NOT measure capacity. With a rounded, odd shaped tank, such as a motorcycle, the top half won't get you as far as the bottom half. But at half full, your still half full. You would do better to use an hour meter as a guage. After a while running you can determine just about how much you use per hour. Just like you would do in a car if your guage quit, you could use the trip meter to determine miles traveled, divided by your miles per gallon, when to buy more gas.Originally posted by RebelRipper:<br />the fuel guage reads 1/2 full when the fuel tank is way more than half full.
