starcraftkid
Thread starter- Joined
- Jul 5, 2010
- 238
The trailer that came under my Starcraft Capri has two independently hung axles, which are spread a bit farther apart than normal too.
Both axles are fixed position, the shackle hangers are welded in place, it's got four 1,000lb springs on two one ton axles.
It uses four slipper springs each mounted to it's own brackets.
One thing I notice is that on uneven ground, or when backing down a ramp, it often leaves the second axle hanging in mid air. It tows great, but I suppose that's due to the fact that the axles are at the very back of the trailer and there's a few hundred pounds of tongue weight. The boat only weighs in at about 1250lb or so with the 50hp motor on it now, and I tend to keep most of the weight towards the stern when towing too.
The trailer came from FL, its made by Web On trailers in Miami.
I see they still make the same trailer, so I'm not sure how old this one is, but the boat is a 1973.
I do have to lower the boat a bit on the trailer. The bunks sit about 3" higher than they need to. And I can probably lower the fenders a tad bit too to gain even more room.
Is there any advantage or reason for the axles being spread apart or hung separate without an equalizer bar in between the springs?
