ODDD1
dstuard
Read a post where you were talking about the blue ignitions. I have an 83 Merc 115 HP that I am having trouble with at full throttle. It bogs down in the hole a little but will eventually plane off. After I get it up I can back off the throttle a little and it will go fine but when I go full throttle it misses. What spark plug should I be using? I currently have Champion L76V. I ohmed the stator and got 6910 red to blue and 6750 from red/white to blue/white. Specs say 4500-6200. Is this far enough off to warrant a new stator? I posted a topic on my problems called Mercury Ignition and I know you are not supposed to make multiple post but you seem very knowledgeable about this stuff and always willing to help. Thanks in advance!
howster
Re: ODDD1
YOU MAY WANT TO START BY PUTTING A MARINE PLUG IN IT THEY BURN ALOT HOTTER COULD BE OVER LOADING ON FEUL CANT BURN IT FAST ENOUGH ALSO CHECK YOUR PRESSURE ON YOUR FEUL TANK MAKE SHORE YOUR NOT LOOSING YOUR PRIME IF YOU HAVE THE BOOK SET YOUR CARBS THE BOOK CAN TELL YOU HOW YOU CAN GET THE BOOK AT YOUR PUBLIC LIBRARY.<br /> THE HOWSTER!!!
dstuard
Re: ODDD1
I have a manual and have tried pumping the bulb. Also tried to mist the carbs to see if that helped. Really acts like an ignition problem. I guess I can try another plug and see how that works. The ones I am using are marine pluga though. Would they require less voltage from the stator to work properly?
