OEM or Aftermarket
Tarks
Im looking at pulling my Alpha One Gen 2 drive and servicing myself. Pump, bellows, gimbal bearing etc. Do most people go OEM or aftermarket? There is a wide range of pricing on aftermarket depending on brand which leads me to my questions. Are there any parts that I should only be considering OEM? Any aftermarket brands I should steer away from? Any brands I should stick to? Ive tried searching but cant really find any good info/reviews on brands. Thanks.
JASinIL2006
I'm not sure about the other bits, but I've heard of quite a few problems with aftermarket bellows. That job is such a pain that I could not imagine using anything but OEM parts. I'd have to have to re-do it in a year because some cheaper parts failed or didn't fit right.
matt167
My rule of thumb is, if the job is 'involved', then it's OEM only. If your thinking about a carb kit, then Sierra is probably fine. If something does happen, you don't have to dig very far to fix the problem.
Grub54891
Oem. Sierra is good for some stuff, electrical comes to mind. They have improved their product line over the years but I'm old school and like oem.
Scott06
Bellows and water pump impellers general consensus is oem is better. On my old boat alpha one gen one, the merc impellers lasted twice as long as the sierra ones
I wouldnt buy anything from sierra except the gauges because I know where those are made. for rubber bits, either direct from the manufacturer of the pump (Johnson, ITT Jabsco, etc. for crank mounted pumps or in the case of a mercruiser Alpha drive, thru Mercury/quicksilver)
Gimble bearing, you can usually buy the Volvo one cheaper than the Mercruiser one (same bearing) however if the bearing is in a kit with the bellows, etc, that is usually the cheapest way.
