Texasmark
- Joined
- Dec 20, 2005
- 14,946
You know, you just have to keep asking questions.
Still working my clutch dog rattle problem. Figure if I can smooth out my idle, I can reduce it since I am running a big bore 3 cyl and idle (675 rpm) is rough for obvious reasons d
So I'm yacking away on here and Silvertip kicks in with a suggestion on changing type of plugs (like he did with a similar engine); from surface gap to a more conventional style.....NGK is the brand. I never did like the idea of surface gap anyway, seems like you are putting a short circuit right across the electrodes.
So I go to the NGK site and stark digging around for information. First of all I go to their plug selector and brouse thru the plug types offered for a couple of Merc engines in particular. Noticed both use the surface gap.
Plug in that model number for info concerning it and lo and behold, find out that the surface gap is recommended for two extremes of operation to reduce fowling: One is continuous WOT operation and the other is long periods of trolling.
Hmmmmmm. I do neither, so I guess I don't have to stay with the OEM recommended plug. d
So, the plugs Silvertip recommended are purchased and installed. All I have to do now is wait till it warms up a tad and take her out and see if this helps. Even if it doesn't they will probably stay for the reason stated.
Moral of the story is don't blindly accept what OEM's put in front of you. They do what they do for a reason. You need to understand the reason and if it doesn't apply, then it looks like you are open to change things up a bit; iif you are of a mind to do so.
We all have our own little world of boating with our unique situation. OEM's have to build equipment for use for everyone of all talents, in all the world, under all conditions, and hope they have a winner. One heck of a design task.
My hat goes off to them, but like I said, if you're careful, and do your homework, no reason why you cain't tweak the recipe for your little nitch. d
Mark
Mark
