Official Business of the 3V Club ( aka tri hull club )
southkogs
Start a topic for it in the rebuilding forums. If you have photos from before you stripped out the deck and the stringers post 'em up there.
The side pieces along the bottom of the gunwale were mostly for stowage. I think your stringers in that boat are all under the deck (not too much side support, I guess is what I mean). Those little 14' boats were a pretty simple flat deck, and two lounges (back to back seating for 4). MANY didn't have carpeting. Very likely this was just a glassed deck.
Tapphouse
Hey south, I do have a pic of the floor right now. It’s not removed, but I did remove a 2ft hole dead Center about 2ft forward of the transom. This spot was wet and brittle, the exposed stringers look “ok” not brittle, but were wet.
It sat out side under a cheap boat cover full of heavy snow for two winters, hence the water and soft spot.
At this point I have nothing into this boat, but I do like it and want to get it on the water for fishing. I’m looking for proper direction about how to handle this situation.
I’m thinking drilling a few small holes to help dry it out and lay over existing floor. Or remove existing floor and lay new wood on stringers IF they are still decent.
For the record this is my first boat, I have zero boat building experience, and the funds to buy a “new” or “new to me” boat is non existent. Any info would be extremely appreciated. Thanks!451FCAC9-11A0-4BB5-9E79-5E3468826BB4.jpegB0B7D87C-0628-4574-B45F-37A262AE62E9.jpeg
southkogs
Do a little readin' over the restoration forums: I can't find a topic at the moment that's a mirror for yours. But there are plenty very similar.
IMHO: to do it right, you're going to have to pull the top cap off the hull (disconnect at the rub rail seam), clean out the deck, put in new stringers (and probably a transom) and then glass over a new deck. It's a LOT of work.
If you like the boat, and want the project: then it can be done. Probably a few thousand bucks to get it right. And the boat won't be worth much more than what you paid for it (doesn't work like old cars).
If you really just want to go fishing ... I would look at some other options. You said funds are tight: an open row-boat style 14' with a 10-25HP tiller steer on back will do a great job. And you can probably find one much cheaper than this boat will be to rebuild.
Strychn9ne
Just got myself a tri hull, so maybe I can be a part of the club! I’ll get some more pictures when it clears up outside and I can take it out! I bought it last week and stuffed it in there quick before the rain started and all my days off since it’s rained🙄 It’s a 1976 Hy Ryder tri-15.
Strychn9ne
Thanks, glad to have found this little group! It appears tri hulls are getting more rare, although I see lots of them yet all over here in Wisconsin. Maybe they survive longer here because they can only be used 6 times a year before it’s -35 degrees out again.
Strychn9ne
Well took her out for a little voyage with my daughter down the river and she ran perfectly! Not a drop of water in the bilge and the engine ran great! Even in the long slow no wake zone, no sputtering, just consistent putting. Can’t wait to get into a lake and let her rip! Got a few pics, but forgot in my excitement to take any on the water lol.
Thank you for having this subject tittle
I think this gets me in the Tri-Hull Club. It's a 1978 Terry ABF. Just picked it up for $1,200.
Hello everyone. A few years ago, I purchased a 16' Ebbtide Dyna-Trak 160. Had every intention of having it in the water by now. However, Life got in the way. Both my life partner and myself have had some medical issues and it's been stored. to say it needs some TLC would be an understatement. I knew it needed some lovin' when I bought it as a project. I'm looking at least a new lower deck, stringers, flotation foam, and most probably a transom. and a new floor covering as well when the deck is finished. The hatch on what is the rod locker will need to be replaced as well.
I am going to be doing a cap off resto of tis vessel. under the consol the decking is delaminated and extremely soft. In the second picture you can see where the Previous owner improperly installed the mount for a seat post, thus allowing water to enter the foam under the deck for years. He also admitted to have been under a few brews to many, and hitting the dock a bit hard...more work to fix. As I can, I will be adding more pictures. Right now I am formulating a plan, and seeing what it will be to fix it up. Not wanting a show boat, but a decent boat I can be proud of.
This will be a first, and may be a bit slow getting started, but will for sure be getting done. More to follow.
southkogs
Welcome aboard! Lots for you in the restoration forums. You can learn a lot and see what others have done on their boats in there.
redfury
It's been a while for me. I've been shoved off to waterless lands ( well not really, just Nebraska ) I haven't touched my boat in 3 years, so when I get back to it, I'll have some maintenance to do. Gotta find a couple of lakes worth dragging the beast to since they are all small here and 125hp motors want to run!
tallcanadian
Hey everybody. Thought I’d pop in and say hi. I’m sure there’s more tri hull owners just waiting to post their boats here. Any updates to share?
redfury
Too busy to boat, that's what's up...Move to a different state, new job, then another new job, then 2 jobs, then move the MIL in and have to figure out how to shove 8lbs of crap in a 5lb bag...keeps a guy busy! I did just finally buy a new house last year that finally got me a garage, and I just hung a pair of rod and reel holders on my garage door...work pretty slick...that's now something that is out of the way but easy to access...no more untangling rods to go fishing....working on removing the frustrations to enjoy the sport.
southkogs
I feel ya'. The last year and half has been nuts for me too. Glad to see y'a around.
