Oil Capacity
EClass20
Another question I have pertaining to oil.
Relates to my other post I think. Merc 3.0L, 140 Help.
When I did oil change, I added 5 qts of oil per 2 different Marina Mechanics that I have talked to over the past few weeks. Saw a post today that stated:
"Being overfilled like that will cause the crankshaft to aireate the oil and cause the lifters to partally collaps. That would sure kill rpm.
Time to fix your oil problem then do a retest."
I checked my manual and it says oil capacity is 4 qts. I called mechanic back and asked him about it he said they always put 5 qts. a Merc 3.0L.
Thoughts??
paultjohnson
Re: Oil Capacity
USUALLY the oilpan holds bout 4 and a add a qt for the oil filter. Thats what they SAY.. However I have learned thru 30 yrs of wrenchn on all sorts of engines Acapacities are APPROX Go by the dipstick !!
sethjon
Re: Oil Capacity
Thoughts??
I believe that 5 is correct.
Alumarine
Re: Oil Capacity
Just changed the oil and filter on my 74 3.0 and it took 4 US quarts.
