Oil Change / 4-stroke 6hp?
JimXeod
Total newbie here, and I did do several searches! I recently bought a 2000 Nissan 6hp 4-stroke. I have found tons of info on changing the lower-unit oil, but nothing on a regular oil change? What is the consensus of oil change intervals?
Thanks for all your info, I have found lot's of info on the oil itself, but no info on how and when. I am not at the motor, but I assume it is pretty straight forward, right. Also no oil filter?
Thanks again!
Jim
Mas
Re: Oil Change / 4-stroke 6hp?
At the very least, change the oil once a season...but depends on the amount of use and conditions.
pvanv
We do 'em every season, or at least every 50 to 100 hours. No filter on the 4/5/6. The drain is under the forward lower cowl. 10mm wrench fits the hex cap screw, with aluminum gasket. Be sure to use FC-W rated oil. Do not overfill -- not even a drop. Best to have the oil half-way up the dipstick.
TGuy
when all else fails, read the owner's manual. There is a section in your owner's manual that shows you how to change the oil, complete with pictures, etc (and a section which describes how often, etc).
If you can't find your owner's manual you can download a free PDF copy from the Tohatsu and/or Nissan Marine website (www.tohatsu.com or www.nissanmarine.com). Look under the tech info section for the manuals or click the link on the top of each page.
TOHATSU GURU
For what its worth.......10w-30 oil, do not use synthetic oil and 25 hour oil change intervals.
