Oil Change, please help
88skiboat
I'm going to change the oil in my 351w (inboard). There seems to be a lot of schools of thought on this and I can't seem to get a straight answer. What do you recommend for engine oil - 10w-30??? Can I get the oil and filter at an autozone or alike?
Thanks
Re: Oil Change, please help
Ayuh,... You can use Whatever oil you Want,... None of it will Hurt your motor, if changed regularly....
I shop at Napa,...
bigskiohio
40w if it is run in warmer temps
Howard Sterndrive
depends whether or not you have an engine oil cooler.
If you do, 10W30
If not, go heavier, e.g. 20W50, 25W40 or straight 30
backyard mechanic
The API (American Petroleum Institute) recommends a 5-20 oil in all engines but diesel. Google API and you'll see for your self.
Yes, 10 - 30 or 10-40 will do as well as any oil. Consider the reason why API suggests you use 5-20 oil; The greatest amount of engine wear comes at start up. Therefore the lighter the weight of oil to get pumped around when first started the better it is for the engine. :)
airdvr1227
The great oil debate. It's all marketing. Don't fall for it.
Howard Sterndrive
wow, they sure don't
that's some seriously bad advice that I hope no one takes
obviously, API recommends you follow your vehicles owner's manual
and 5W-20 would be a good way to wreck a boat engine unless it has an oil cooler or is being used in northern climates in the winter
jay_merrill
I'm in need of a little gallows humor ...... I know where you can get A LOT off it, really cheap!
Can you use "10W - 800?"
ENSIGN
Were goin to beat this post to death! Just use a high quality product:)
