Oil commig out of my plugs
Jeffneal1988
I fired up for the 1st time. The motor was fogged for winter and I fired up and I had to have the warm up lever up in order for it to run. Smoked really bad so I'm not sure if it's getting all the fog out. Every time I would put the lever down motor would die. I pulled the cover off when I got home and noticed ouil around the plugs. The motor is a 74 115hp evinrude. I'm pretty sure I had the gas ratio right 50:1 this is my first boat so I hope I mixed it right but I'm not sure whats going on is this normal.
boobie
Re: Oil commig out of my plugs
Put some new plugs in it and torque them to specs. With the new plugs you'll have new plug gaskets.
