Oil consumption issue
V-Tech
I recently acquired a 2000 150 HP Johnson that seems to have excessive 2 stroke oil exhaust smoke on cold start-up and during warm-up. After it has been driven and "blown out" 2 cycle smoke seems normal. Are these outboards known for this or is there likely a problem with the oil injection system?
boobie
Re: Oil consumption issue
If you can get an OEM service manual there are oil consumption tests in it. A fuel restriction will also cause you a high oil consumption. Testing all this will be in the manual.
tashasdaddy
if oil tank is higher than carbs, oil can siphon into the bowls.
V-Tech
Thank you guys,
The oil reservior is not higher than the carbs.
any kind of rough idea how much oil should be consumed in 10 hours of moderate cruise?
I don't yet have a manual.
boobie
I don't feel like doing the math tonight but it should work out to be a 50:1 ratio meaning 1 pt oil to 6 gal fuel even tho you have an OMS on it.
