Oil dip stick tube - 1998 Volvo 4.3GL
Jobe_Pro
MY Volvo 4.3 GL has outside threads on the oil dip stick tube which a female hose will thread on to, my question is can I siphon oil out of the engine simply by threading a hose to it, does the dip stick tube go to the bottom of the engine oil pan? or do I need to buy an oil extrator pump?
Don S
Re: Oil dip stick tube - 1998 Volvo 4.3GL
Siphon out ???? No, you will need a pump.
The answer is right in front of you. Follow the dipstick tube and see where it ends.
Jobe_Pro
Ok suck with a drill pump or a pump & hose adapted to thread to the dip stick tube.
yes I was going to do that but to save time I thought someone would know this already, thanks.
I see there was already a similar thread on this same question pretty much that I missed from 2 years a go, my bad.
bruceb58
Honorary Supreme Mariner
Dip stick tube travels to where the drain plug would normally be via some fittings. I always used a small hand pump like this one
I have since switched to one of these because it is less messy.
