Oil Drain Kit
KaGee
Re: Oil Drain Kit
Originally posted by SeaRay24Sorrento:<br /> Oh and did I mention water too. (Heavier than oil).
If you got water in the pan, you have bigger problems than how to drain your oil.
Paul Mariz
Re: Oil Drain Kit
Yes I agree with Bondo <br />I did it with a 12 volts pump kit, it works fantastic<br />And i say the Time you espend in your Boat shouldend really matter, after all it take's you around all summer long ( nes pas )<br /><br />PePere<br />Canada,Quebec
scottatwork
Re: Oil Drain Kit
I tried the pump thing, bought a very nice model but you MUST do what the instructions say and warm that oil up, if it's too thick it just spins......it was a messy job.<br /><br />That hose looks like an awesome idea.<br /> <br />Currently I have a 1 gallon prestone jug, I pull the plug, let it fill, put the plug in, drain the prestone jug and do it one more time.......it's ugly too but not near as messy as I thought it would be........
b45701
Re: Oil Drain Kit
Tahoe Bob, where did u get the kit u have on your boat. I like that setup and would like to install on mine. <br /><br />Thanks.
FreeBeeTony
Re: Oil Drain Kit
I got mine from go2marine..........<br /><br />But I decided not to install it anyway.........<br /><br />Had a hard time getting it on after I installed the engine.........couldn't get the fitting started.<br /><br />Costs about $40......let me know if you're interested.
am_dew
b45701
Re: Oil Drain Kit
Can't tell from the pic. Is there a valve on the fitting that connects to the pan?
am_dew
Re: Oil Drain Kit
No valve on the fitting that connects to the pan. You simply snake the screw capped hose out the transom plug hole and then unscrew the hose cap while you hold the hose higher than the oil pan so the oil does not come out while taking the cap off. Once the cap is off, you put the hose into a container, lower the container to ground level and the oil starts to drain. When I think it's all drained, I blow gently into the hose to see if any oil is left in the pan...if so, I suck gently in an attempt to siphon off what little is left and then place hose back into another container to see if any more oil comes up..I usually get a couple more tablespoons after doing that.
Johnv
Re: Oil Drain Kit
I have used a less expensive but similar approach to the oil drain hose. Cut out the side of an antifreeze jug and tape an old length of garden hose into mouth of jug. Place cut out jug under drain hole and feed garden hose out boat's drain. When oil drains into jug it can run out of boat into other container. Works really well if engine is run a little while and oil is warm. Price is right!!!
Lou C
Re: Oil Drain Kit
Just get the best suction pump you can find, if you are patient and take your time you can get just about all the oil out, at least close enough that it will not matter in the long run. If I were starting with a new engine I might consider the drain hose, but I still would be concerned about fittings/hoses leaking in an inaccessible part of the bilge.
FreeBeeTony
Re: Oil Drain Kit
Lou C..........after thinking about it more, I had the same concerns as you an decided not to install.<br /><br />Now I am stuck with this kit..........<br /><br />If anyone is interested let me know.......
Paul Mariz
Re: Oil Drain Kit
Hi guy as i am new arrived at this site, and not to expert on computer a got a question, how do you includ a picture under your names, can you help me. Appreciated, i find that very cool.<br /><br />PePere<br />Canada,Quebec
Re: Oil Drain Kit
Originally posted by PePere:<br /> Hi guy as i am new arrived at this site, and not to expert on computer a got a question, how do you includ a picture under your names, can you help me. Appreciated, i find that very cool.<br /><br />PePere<br />Canada,Quebec
PePere,.......<br />Go down to Either Dockside Chat or the Non-Boating Technical forums,+ ask this Question There,........<br />Actually,.....<br />I Think this topic has been discussed in 1 or Both of those forums in the last Week or so...............<br />
Now I am stuck with this kit..........<br /><br />If anyone is interested let me know....... <br />
Tony,........<br />I can't see the Oil Pan Fitting in the link at the top of the thread,.........<br />If it's 1/2" /20 on the Pan side,.......<br />What's the thread on the Line side,..??......<br /><br />I haven't gotten that piece for the Bored & Stroked 327 yet,........... I Might be Interested,..??......... ;)
