hi all, honda 115hp 4stroke 2002. i am having some running issues with my engine so today i had a look at the fuelfilter and it has oil in it. i guessed that the oil was maybe getting in via the lp fuel pump,i took it apart and found oil inside. i cleaned the fuel system out from tank to injectors, i then ran the engine and at first was good then started bogging down and stalled. restarted then limped back in. i reopened the lp fuel pump and was clean inside. my question is can oil get into my fuel from somewhere else? hp fuel pump? does this engine have a fuel cooled oil cooler? sorry another question, can the lp fuel pump leak air pressure from the camshaft into the fuel system?, i ask because i am getting air in the fuel system but downstream of the engine mounted filter. thanks for any input
