oil in fuel pump inlet.
pokefan7790
I have a 1993 120 hp evinrude with VRO. I removed the fuel line from the pump inlet and there was oil in the fuel line. Is this a problem? I am disabling the VRO.
boobie
Re: oil in fuel pump inlet.
As long as your disabling the vro and mixing 50/1 fuel don't worry about it. You may have to pull the carb float bowl drains and flush out with fresh fuel.
