Oil Injection hookup for 90 HP Evinrude 2006
siviglia
I had purchased a 90 hp evinrude (2006 model) 2-stroke, (Not E-Tec) and had the option to install oil injection when I had it installed. I elected not to, however now the boat is beeping and the "no oil" light is illuminated (oil is added through the gas tank). My question is #1...Is there a way to disable the no oil light and aural warning...and #2... if not, what guide can i purchase that will walk me through installation and acquiring the correct parts for setting up the oil injection.
johnrude
Re: Oil Injection hookup for 90 HP Evinrude 2006
You can remove the tan wire from the harness on the OMS pump. Best thing to do is purchase a oil tank and hook it up. You will not have a problem with it at all.
