oil injection problem 1989 200h.p yamaha oddysea1
oddysea1
This problem started out on a intermittent basis over several months. The led gauge would flash several times while the engine was running ,ocassionally low oil alarm would go off.Now when turning over motor the led arrows flash only once and sets on green light vs other working motor which flashes 4 times before setting onto green light.The alarms work ,the pump when bypassed directly to battery works.The problem is oil does not go to power head tank from main tank ,also the emergency switch does not work.Any sugestions would be appreciated.As of Sept 24 possible fix I cut the plug connector off of the maintank pick up tube and pump and reconnected directly.STill having same problem, I do have power going to main tank pump however pump works only if directly bypassed to battery.The led gauge only flashes once before arrow goes to green.Question does the gauge dictate any function or just give the inputted information?
99yam40
Re: oil injection problem 1989 200h.p yamaha oddysea1
Do a forum search for oil transfer or look at some of the similar treads at the bottom of the page.
oil transfer problems has been covered many times
