Re: OIL INJECTION SYSTEMS
I'm sure someone disabled your system and went to pre-mix. More than likely the plastic gear inside the motor started to get stripped out. This is very common for this motor. I have the same motor 85 150 xr2, and my gear went bad, so I went to pre-mix. I also have a parts motor, and the reason its a parts motor is because that gear went bad, oil pump stopped working and it fryed the motor. I would stick with pre-mix! You know your cylinders are getting the oil they need. Just my two cents. Good luck.<br />CU<br /><br />--------------------<br />RUNNING THE MOTOR WHILE LISTENING TO THE HORN WILL MAKE YOU MORN!!
