billysboat
Thread starter- Joined
- Apr 24, 2010
- 50
I don't know if this is a problem or not , but I keep trying to resolve a lot of little issues in getting this boat right.
This motor is a ford 351 with a volvo outdrive. It's a brand new motor. My oil pressure seems real high, It's reading 80 psi. I'm using straight 30 weight, but I think it may be the gauge. I'm gonna hook up a mechanical gauge later to check it out. I noticed there is no PVC valve so I put one on. I hooked it to the back of my hollye 4160 carb. It smoked quite a bit and burned a quart of oil up pretty fast. So then I disconnected it, it stopped smoking and then seemed fine.
Each of the valve covers has a breather and they are saturated in oil. I'm wondering if this is normal. So, does anyone no if there should be a pvc valve connected and if so where would it go ?
