Oil leak at fuel pump????
peanutbay1
We took our b-liner 2755 out for its maiden voyage after 3 years of sitting in a boat yard . It runs very good but we found an oil leak near the fuel pump. It only pushes out a little oil at high rpms ,the fuel pump and surrounding area (coolant hose..) get a small spray of oil. The engine oil is honey gold and I am sure we have no cracks. Can the gaskets be fatiuged from sitting dormant for 3 years?? Should I regasket the fuel pump. This is a 1990 5.7 mercruiser. Very low hours and in beatiful shape.
Jeepster04
Re: Oil leak at fuel pump????
Yeah, could just be a bad gasket around the fuel pump.
Ayuh,... It might quit by simply Tightening it...
Or,...
It could be the oil pan is Rusted thru...
peanutbay1
I will check both suggestions. Thanks again!!!!!
freeone
see the two holes in the pic one has a bolt in it(orange). directly behind the pump, front of block directly below the water pump mounting surface. i have had 2 blocks spray oil out of those holes at high rpm/load and seen others with it already plugged with the bolt as seen here or some people use the allen head plugs for a cleaner look . check those b4 you take the pump or pan apart.
peanutbay1
You learn something everyday!!! Thanks guys I will check that tonight. Something makes me think I have seen the lower tapped hole with no bolt in it. I love this forum!!!!:D
