Oil leak behind prop - help please
jhanna
I recently inherited a 1979 carrera 24-1/2 ft cuddy cabin w/ a 454 Chevy. before taking it out, I had a mechanic go through everything to make sure it was sound. The only problem he wasn't able to take care of was an oil leak in the stern drive - a leak coming from just behind the prop. this mechanic told me that this stern drive, with no markings and all black, was built by a company called "stern power" and that they were out of business. This mechanic, who I will never use again, said I could put it in the water but to just keep an eye on the oil level. Against my better judgment, I put it in the water and after running for about two hours without incident, the oil leak turned into a water / oil leak and there was a lot of it. Being away from home, I took it to second mechanic to trouble shoot the oil leak. This mechanic took it apart and found that the prop shaft, which itself was maybe about 10" long, was scored and roughed up and someone had put a small sleeve over it about 3" long. The second mechanic thought that the sleeve caused the prop shaft to be roughed up. The second mechanic also said that my stern drive was a "Dana" and that he couldn't find any parts for it. At this point, I'm thinking that maybe I need to replace the stern drive with a merc, volvo or OMC. The second mechanic suggested a merc drive but since my boat has a transmission behind the motor, it would be quite a project to change it out. Since there's a transmission behind the motor, there's extra space that would have to be made up some how. Its a nice boat and I'd hate have to throw in the towel on it. I'd like to have the oil leak fixed and, if not, know whether or not its possible to change out the stern drive for a reasonable price. The second mechanic said that a power package from Mercury Marine would cost about $5700 plus a lot of labor in installation, cutting a new hole in the transom and moving the motor back far enough to accommodate the new drive. Total charge for this project would be about $20k. Forget that!
does anyone have any experience with a boat and a set up like this? Any suggestions?
Re: Oil leak behind prop - help please
Ayuh,... Got a picture of this drive,.... It sounds like a Mercruiser TR or TRS...
