Oil leak coming from this hole?
dubs283
that is a starter mount bolt hole, no connection to any oil passages
looks like you have some oil traces up higher on the engine, perhaps valve cover or pushrod cover gasket(s) leaking?
Obriont
Not sure. Im having a hell of a time finding it. It sprays everywhere every time I use it and cant see where it is coming from
dubs283
the oil pressure sender is right above the starter, could be the culprit
clean all the oil off the engine, run at idle and check sender, valve cover and pushrod cover for leaks
