I am kinda of new to boating have a 1998 Johnson 2 stroke 70HP that I just got for fishing a particular lake up in Northern Ontario heard the motor run with the watewr muffs on it but haven't put it into a lake yet.<br />When I took the motor off the transom saver and put it in the vertical position a very small amount of dark sticky oil dripped on lthe floor--it is not coming out where the cotter pin and nut are but it appears to be coming from where the outside diameter of the prop is the prop guessing is about 6 in. in dia. and it is coming out from that area where there is a small gap when the prop is rotated by hand.<br />Hoping I lhave explained the area well enouth.<br />Any help with this would be nuch appreciated thanks len
