AnonymousBoater
- Joined
- Dec 20, 2007
- 97
Ok, as some of you know I had a bunch of work done on my Volvo Penta 3.0GL. Also had the transom rebuilt..but thats beside the point. When they reinstalled the motor after doing some engine work they pushed the oil drain tube "block" into the bilge pump. It is leaking where the arrow is and following the path that I highlighted. Now the million dollar question is, that big bolt that I pointed to, If I loosen it, turn the block so it doesn't push into the pump, tighten it do you think it will stop the leak. Is that what that bolt does?
Sorry for the dumb question..
