I have a Mercury 7.5 hp motor. I've replaced the water pump and impeller. I also replaced the prop seal and shift shaft seal. I've done a compression test and found no leaks. I also ran the lower unit in a 5 gallon bucket using an electric drill and no oil leaked. Everytime I put the motor back together and run it in a barrel, I get oil all over the place. Is there anything else I can try, before I bring this thing to a pro.
