Oil leak
Libby66
I have a 04 Yamaha 50 TLRC 2 stroke that I just replace the oil injection pump and since then I have oil leak from the weep holes in the lower unit, not sure if I did something wrong or missed something. Any help would be appreciated.
99yam40
drop the lower unit and see if 2 stroke oil is runing down the drive shaft from the pump.
This is assuming that this is clean 2 stroke oil you are seeing dripping out of the lower unit and not lower unit lube
