HI, I HAVE YAMAHA 1988 150 HP MOTORS, WHEN I PULLED THE PROP I NOTICED OIL LEAKING FROM THE SHAFT, ALSO WHEN I DUMPED THE LOWER UNIT OIL IT WAS WHITE TELLING ME THE SEALS ARE BAD. RIGHT UNDER THE PROP THERE IS A SEAL THAT IS TORN UP. I WAS TOLD THAT I CAN JUST PULL THE PROP SHAFT AND NOT THE BEARING TO REPLACE THE SEALS IS THIS TRUE.
