ok the motor is a 1978 470 mercruiser.. has been running good but now it will idle fine but under a load it will shoot oil out of the dipstick.. I had a good amount of oil on the deck. I put oil back in and idled back in but when I would try to give it gas it would do the same.. about a month ago I disconnected the hose from the valve cover to the carb.. (blow by?? not sure what it is called) that was spitting some oil in the carb and causing her to stall, but that was a month ago and it has ran good until now???
also the oil to me looks thin but I dont think its water , the coolant level is full..
any help is appreciated
thanks
Nick
thanks
Nick
