Re: Oil out of the Vent Tube
If he does have a PCV valve on the engine someone would have added it, as it would not have come stock. All that's on the 3.0ls is a brillo pad in the fill cap or a plastic elbow vented to the flame arrestor.
My old 1975 888 has a PCV valve --- just wondering why some boat engines do not have one --- I can not think of a reason not to have one
Because the plastic elbow was replaced by a PCV valve at one point along its life by a previous owner. The elbow is fine.
The reason for a PCV is to help keep contaminents out of the oil, it has nothing to do with emmisions.
Thats actually not true at all. All a PCV valve does is this.... When you heat oil, any kind of oil, it fumes. Those fumes are noxious, polluting, and they don't smell all that pretty. When the engine is running crankcase pressure opens the valve and vents the fumes into the engine to be burnt along with the rest of the gasses. When the engine is off there is no crankcase pressure and the valve closes, and traps the fumes and the odor inside of the engine. That's all it does. It is in fact for emission control, and because marine engines are not subject to the same laws that govern automobiles they are not required by law to add them. (Yet)
They have been on engines since the 50's for sure and probably longer than that.
That is not true either. PCV valves are mandated by the EPA. And since the EPA wasn't formed until 1970.... well you get the picture. Heck GM didn't even invent the PCV valve itself untill almost 1960. So Marty McFly... who got in their delorean and started installing PCV valves on engines 10+ years before they were even invented... let alone mandated??
IMHO -- boats should have their fuel vapors run to a carbon canister --- one way check valves --- sealed gas tanks etc.,
You obviously do not understand the boat building process. Besides... you think boats are expensive now??
To the original poster....
There is a slight bit of oil coming out of the vent tube that comes out of the top of the valve cover and hooks to the side of the carb
Define "slight bit" better... Are we talking you stuck your finger in the hose and it came out oily and black. Is the hose dripping oil on the manifold? Is it spraying oil everywhere???
