further
Thread starter- Joined
- Jun 18, 2009
- 1,038
Guys,
I unfortunately found an oil leak originating at the junction between the oil pan and drain fitting... UGGGHHH:mad-new:
Looks like there are some o-rings and washers there and I'm hoping that its just as simple as the replacing the oring and washers item #'s 49, 57 and 58
http://www.volvopentastore.com/mall/image/view/7/7/12482_1.png
I do have a little bit of rust on the pan where the fitting is but I definitely see that the leak is originating at the junction of the fitting and the pan (I wiped it clean and then with a mirror watched where the oil came out from. It's a very slow drip.
Here's a photo
REALLY REALLY REALLY don't wanna have to pull the motor.
Is this fitting screwed in? Can I unscrew and replace the washer and orings?? Hope for the best?
Seems like every time I go to fix/replace one thing I find another issue:facepalm:
thanks in advance for all your input!
Here's a photo
