Oil pressure gauge
fyrfightr
93 4.3L with Gen II drive. When I turn the ignition switch on the oil pressure gauge pegs at 80lbs. Stays there when engine is running. If I unhook wire at sending unit, gauge reads zero. Replaced sending unit today. Getting same symptoms.
Tried testing the new sending unit today with VOM. did not get change like I thought I would.
I assume I have oil pressure as the idiot buzzer goes quits when I start the engine.
I have been having this issue since getting this boat 3 years ago....
tupperj
Re: Oil pressure gauge
Fyrfightr,
Don't know of you have the manual or not, but the troubleshooting section calls for a reading of about 240 ohms across the sender with the engine off, and about 100 ohms at 40 psi.
Pegged meter should mean a short to ground.
Is it possible you have a dual station sender installed? Manual says it should have 353M stamped on it. Those senders show a much lower resistance for a given pressure evidently.
I'd be looking to T in a standard gauge just to be sure you know what the engine in doing.
Good luck!
Paul
Edit: this info is for a 3.0 engine, don't know if it's applicable to your 4.3. Need to pay more attention!
fyrfightr
Will have to go take an ohm reading on the old sending unit and see what it says...
fyrfightr
I get a readings of 380 one direction and 500 the other direction using a digital ohm meter.
