93 4.3L with Gen II drive. When I turn the ignition switch on the oil pressure gauge pegs at 80lbs. Stays there when engine is running. If I unhook wire at sending unit, gauge reads zero. Replaced sending unit today. Getting same symptoms.
Tried testing the new sending unit today with VOM. did not get change like I thought I would.
I assume I have oil pressure as the idiot buzzer goes quits when I start the engine.
I have been having this issue since getting this boat 3 years ago....
