Oil Pressure Sender on Aq130
pcmpete
My Aq130 has the standard oil pressure switch fitted, but I want to fit an oil pressure sender that will work with a gauge. But the sender does not fit because of the copper cooling pipe going into the oil cooler. Are there adapters available will mount the sender at an angle to clear the pipe?
Thanks
Re: Oil Pressure Sender on Aq130
Ayuh,.... It's mounted with pipe threads, Right,..??
Any Hardware store will have brass fittings for it...
pcmpete
Thanks Bondo, took your advise and visited Lowes :)
Got a setup that will place the oil sender 90 degrees to the block, should work out just right.
Thanks again
