Oil Pressure sender/switch question
dmoccia
This should have an easy answer. On my 2005 Mercruiser alpha one gen 2 3.0 liter engine: is the oil press sender and the oil pressure switch both contained in the same housing. In other words if I order a new sender will I also be getting the switch?
Yes and No
The sender and switch is sort of connected in the same area (not housing). It is usually located near the remote oil filter is connected at the block by a Tee fitting.
If you order one you only get the one you ordered, not both
Don't know your serial number but item 4 is the sender and item 9 is the switch in this pic
https://www.mercruiserparts.com/bam/subassembly/30907/12824/40
dmoccia
