Oil Pressure
mmarncic
What should the oil pressure on a 1996 Mercruiser with a 3.0. Mine runs about 25 to 30 psi. Doesn't seem high enough to me. Thanks for the help.
Re: Oil Pressure
Ayuh,...
10psi. per 1000rpms is normal.... Has your's Changed recently,..??
Don S
Re: Oil Pressure
At idle, minimum should be 5-6.5 psi, at 2000 between 30 and 60.
Check it with a mechanical gauge before thinking you have an engine problem. Could be a gauge or sender problem.
mmarncic
Re: Oil Pressure
thanks. At Idle it's about 10. At 3000 RPM it about 25
I'll check with a gauge before doing anything else
Robj
Re: Oil Pressure
What weight oil are you using? I believe Merc recommends 25W40. Don has posted the Merc recommendations on other oil threads. If the oil is too thin that will also result in lower pressure also.
Have a great day,
Rob.
