Oil pressure
Pdevito
I changed my oil and filter it emptied as fast as i filled it to the bilge what could it be
Please do not start multiple threads
You most likely have either a rust hole or other issue.
Plan on pulling the motor (pull the drive first)
Pdevito
Sorry didnt see it go. Hope its not a hole never burned any oil for a year
If it only leaks when the engine is running, you may have the wrong filter or the old gasket was still there when you screwed on the new filter
If it leaks as you are pouring it in. You have a hole
Pdevito
Its strange but i filled the 1st 4 quarts as usual then it drani 3 more which would be too much. I drained 5 out of old oil. So i knew something was wrong. Its a i/0 pontoon so almost impossible to see under. Tried a selfie stick with phone and saw the pan but wasnt leaking. Im going to have someone fill while filming.
It didn't leak any oil and now it drains out as fast as it's poured in?
Drain plug issue
ROY WILLIAMS
SO the engine oil is that engine oil drain plug ?
also the engine oil draining the electric/hand pump oil stick port hole ?
Pdevito
Never touched plug cant find it. Removwd by electrix pump from dipstick bass pro thinks dipstick may be brijen or loose but its emoty to thr very bottom of pan. See vudeo
  • 20240126_103711.mp4
  • 20240126_103746.mp4
ROY WILLIAMS
Never touched plug can't find it. Removed by electric pump from dipstick bass pro thinks dipstick may be brijen or loose but its empty to the very bottom of pan. See video !
on my god ! the boat engine top the wood/fiberglass around the engine ?
Pdevito
Yep hard to get under. There is a hose conne ted to the oil pan going up. Cant find in mNual what that is.
stresspoint
guessing ? , that could be one of those oil drain devices where you have a petcock that allow you to send a hose out the boat drain.
possibly it is in the drain position or the hose is split.
Pdevito
Its a vacum pump with a very small hose takes hours to empty. It did remove 4.5 gals as normal but when refilled then kept filling so leak happening . Im going to tape the fill this time when it starts. Maybe ill see it. Just need my son to help. With filling or taping.
flashback
This hose is probably connected to the drain on the oil pan for draining the oil thru the garboard drain hole. the hose may have a leak in it. it's not oem so wouldn't show up in a manual.
