went out and took oil pump out and pulled fiber cyclinder off of steel spline shaft and look back inside and seen fibers pulled out shaft seen a lot of fiber pulled out fiber seen gear is it made of a type fiber is it a easy fix or a costly hard fix at dealer.... that's why the pump wasn't turning causing the pump sensor to pick up that it wasn't rotating. ser OG815652..
