oil pump found problem 1999 xr6
venture
went out and took oil pump out and pulled fiber cyclinder off of steel spline shaft and look back inside and seen fibers pulled out shaft seen a lot of fiber pulled out fiber seen gear is it made of a type fiber is it a easy fix or a costly hard fix at dealer.... that's why the pump wasn't turning causing the pump sensor to pick up that it wasn't rotating. ser OG815652..
j_martin
Re: oil pump found problem 1999 xr6
Why don't you put all your posts on the same subject in the same thread? There are at least 3 on this one topic.
It takes a major teardown to replace the plastic gear on the crankshaft. There is an electric aftermarket VRO pump that is very nice, and considering labor much cheaper than fixing the original. If you are in a bind, you can always mix your fuel 50:1 in the main tank and run like that.
It's always a good idea to remove the pump and make sure it's all free and looking good as a spring setup task. They most often fail when they gum up in storage. First crank on the engine shears the gear.
Serviced regularly and run under 6500 rpm, they seem to last forever.
hope it helps
John
venture
Sorry about trying to figure this out about posting. But back to the oil pump sheared gear but I understand it cost to much to break dow and I know that I can mix 50:1 in main tank Should I put the shaft back in or leave it out and should I unhook the hoses and electrical to the beeper, and were can I find the aftermarket vro electrical pump what do you suggest that I do........ THANKS
j_martin
If you remove the pump, you should put in a block off kit that holds the bushing in place, else it may fall into the engine which will get serious indigestion trying to chew it up.
Marine solutions makes the electric pump kit. Highly recommended.
Here is one source
http://www.go2marine.com/category.do?no=13750&view=item
If you want to premix your fuel, here's instructions for removing the oil injection system completely.
http://forums.screamandfly.com/forums/showthread.php?t=57758
The kit is about ten bucks at Mercury.
hope it helps
John
