Re: Oil resevoir not filling up??Help?
I had a similar problem on my 1985 150 etxks. The switch on the motor ( manual/emergency ) fill switch was the problem. On mine if you use that switch, you have to bleed the oil system, as air gets into the line. I had a hell of a time with it. The so called mechanic on two occasions utilized that switch, and when I got out to the middle of the bay, the alarm would sound, and the rev
limeter would kick in, and I would have to put back in. I purchased a Seloc manual, and thats what I found out.
