Oil sending unit 7.2l Mercruiser
eastont
My oil pressure gauge is not showing any reading at any rpm, so I'm guessing that it'snot the oil pump but either the sending unit or the gauge.
Where is the sending unit located on the engine ?
Fun Times
Did you mean 7.4L?
Do you have your engine serial number handy? If not, what year and model do you have? Carb or MPI?
Also did this just happen or after an oil change?
eastont
Yes, 7.4L
It is an 1989 carb and it happened as soon as I fired the engine up after winter storage.
Bt Doctur
either its located to the right and rear of the dist, or just above the oil filter
