1999 Mercury 150 EFI
Running on Lake O last week when Beep Beep Beep sounded.
Top resovior is fine as well as lower unit. Checked Cap Sensor with Ohm meter and it works correctly. No reading when float at top. Full reading when cap is at bottom of stem.
I think the oil pump is OK as when engine is running I crack the cap on the top and oil flow out. After tracing wires I see that one goes to the front of the engine with a red LED on it and it also has a wire going to the bottom of the fuel filer. The other sensor box is located towards the rear.
Any ideas???? I premixed oil just in case and it seemed to run ok all day, as I had a tourney!
Any Ideas???
Any Ideas???
