Oil Types – what can be used in two strokes.
SnappingTurtle
I have in the past used Castrol Racing, or LIQUI MOLY Racing, full synthetic two stroke oil, all with a TC-W111 rating.
My neighbor just gave me :D a couple of liters of LIQUI MOLY semi-synthetic two stroke oil, with these ratings listed: API-TC, ISO L-EGC, SCC TSC-3.
Can this safely be used in my small outboard?
With oil costing what it does today, I hate not to use it if I can.
It will be run in a 1981 Evinrude 6HP, and I don't plan to mix the oils.
Thanks!
tashasdaddy
Re: Oil Types – what can be used in two strokes.
outboards are suppose to be tc-w3 rated, that's in the states, have no idea of the German equivalent is.
SnappingTurtle
Thanks for the input.
That is what I normaly use here, I just wrote it wrong, or different from the way you have written it. It is normally written as TC-WIII, TCW111, or TCW3 on the container.
The other oil from LIQUI MOLY is described as for lawn mowers, chainsaws, & motorcycles, and has "TCW3" missing from the proof ratings. This is about $60 worth of two stroke oil, and is not a cheap oil. It would be nice to know if I can safely use it in the motor or not.
tashasdaddy
made for air cooled motors. i would not use it.
SnappingTurtle
There are a lot of two stroke, water cooled, high performance motorcycles here, but I think I will stick to the really good stuff.
I prefer to over do it with quality when it comes to oil. I'll think I will leave the oil experiments to someone else, unless I find something from the company that says otherwise.
Maybe I will call the company "Info Line".
As always, many thanks!
SnappingTurtle
I called the company.
Both will work. One is just a slightly lower quality oil and is not designed with the same properties as the race oil.
The race oil (TCW3) is 80% biodegradable in water after 20 days (for the love of fish & tree huggers), and is intended for extended higher operating temperatures with less carbon build up & smoke free operation (mine still smokes a little).
... or so the company spokesman. :rolleyes:
