Re: Oil
25w40<br />I guess I need to take another shot at this. I spent a lot of time looking into this subject when I bought my Mercrusier. The wife and I saved 6 years to get this new boat. We cut every corner we could to save a buck. This thing cost 4 times what we paid for our pontoon boat and it was going to get the best of everything. Keep in mind, we were a one-paycheck family with young kids, and the pontoon was as basic as you could get, but new. That was my frame of mind. <br />I spent a lot of time trying research what 25w40 was. Only Merc. sold it. Couldnt find it anyplace other than the dealer. Couldnt even find any reference to it outside of the boat business. I work in the auto industry; you would think this would be easy info to find! I finally got a break one day while buying parts at a John Deere tractor dealer. I through out the 25w40 question. Timing is everything! Just so happened, there was an engineer from one of the oil manufactures looking at some wear problem on this huge piece of farm equipment. I asked the 25w40 question, she laughed, youre the hundredth to ask that. I was told that, the criteria for testing and grading straight weight and multi viscosity oils differ from one another. Any high quality straight weight 30w oil will meet 25w40 requirements, and vice versa. Its the same product, just good creative marketing. I use Valvoline 30w in my Mercruser, I can find it almost anywhere, and the price is OK to.<br /><br />20w50<br />This is a different can of worms! Of the GM owner manuals I have looked at, under engine oil section 6, there is a small note on the bottom of the temperature vs. viscosity chart and also in the text, Do not use 20w-50 or any other grade oil not recommended The guys around here that race, say not to use it in a production engine that has not had the oil passages reworked and a high volume / pressure oil pump and drive installed in it. One friend who dose repair work on the side, says he has seen oil pump shafts twisted and one broken from heavy viscosity oils such as 20w50. He also had some concern that the production oil pump may not be able to push the thick oil to the top end motor parts because of the low pressure they run at, like 60 psi or so. The racer types say they run the thicker oil because of the extreme high temperatures they run at and the oil the gets diluted from the rich fuel mixture they use.<br /><br />Take it all with a grain of salt, but personally I wound stick with 30w
